Sink leaks into lawn?
Discussion in 'General Plumbing Help' started by JewishBacon, May 10, 2019.
  1. May 10, 2019 #1
    JewishBacon
    JewishBacon
    JewishBacon
    Jan 29, 2019
    15
    Maryland
    I was washing dishes last night and then when I walked outside I saw soap suds and a glass of milk I dumped down the drain directly on the other side of the wall where the sink is. What's going on here and how urgent is it I call a plumber?
    Thanks in advance
  2. May 10, 2019 #2
    Matt30
    Matt30
    Matt30
    Professional Professional
    Jan 17, 2012
    2,142
    827
    Halifax, Nova Scotia
    Bring in a plumber. Time to investigate
  3. May 11, 2019 #3
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    1,486
    215
    Boston, Massachusetts
    sounds like your kitchen stack is compromised
  4. May 11, 2019 #4
    JewishBacon
    JewishBacon
    JewishBacon
    Jan 29, 2019
    15
    Maryland
    We dont have a stack. Just an aav.
  5. May 11, 2019 #5
    JewishBacon
    JewishBacon
    JewishBacon
    Jan 29, 2019
    15
    Maryland
    @Geofd
  6. May 11, 2019 #6
    gagecalman
    gagecalman
    gagecalman
    Nov 11, 2016
    68
    11
    Baltimore, MD
    Have you looked into the crawlspace?
  7. May 11, 2019 #7
    JewishBacon
    JewishBacon
    JewishBacon
    Jan 29, 2019
    15
    Maryland
    @gagecalman we don't have one of those either.
  8. May 11, 2019 #8
    gagecalman
    gagecalman
    gagecalman
    Nov 11, 2016
    68
    11
    Baltimore, MD
    My mistake. With the crack in the foundation I assumed it was a crawlspace. Slab not basement.
    Do you only see water when the kitchen is used?
  9. May 11, 2019 #9
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    1,486
    215
    when I mentioned stack I ment the pipe in the wall your (ty) or piping below that (ty )is what your p trap pipe or (trap arm) drains into
  10. May 11, 2019 #10
    JewishBacon
    JewishBacon
    JewishBacon
    Jan 29, 2019
    15
    Maryland
    Yes it's only when the kitchen sink/dishwasher are used. Im worried the pipe going out of the kitchen sink ruptured. On the other hand I read something online where a guy said older homes (Mines a heavily remodeled 1957) use to drain the kitchen sink into a cesspool to alleviate septic tank load. Which was common in clay soils like where we are in Maryland.
  11. May 11, 2019 #11
    JewishBacon
    JewishBacon
    JewishBacon
    Jan 29, 2019
    15
    Maryland
    Could it be a clog? Maybe some liquid plumber will clear me out?
  12. May 11, 2019 #12
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    1,486
    215
    I reread your post you say your lawn only is wet when you use your kitchen.....its not wet all the time if that's the case the cesspool post may be right your gonna have to dig anyway so you will find out
  13. May 11, 2019 #13
    gagecalman
    gagecalman
    gagecalman
    Nov 11, 2016
    68
    11
    Baltimore, MD
    Where in MD?
    You are on a slab correct?
  14. May 11, 2019 #14
    JewishBacon
    JewishBacon
    JewishBacon
    Jan 29, 2019
    15
    Maryland
    Yes on a slab. We're in Waldorf.
Draft saved Draft deleted
Share This Page
Group Builder
