rbs
I'm a plumbing novice with a blocked kitchen sink looking for advice. To figure out where the blockage is I checked how much water it took to fill the pipe. Answer: 2 gallons. (Drainage is insignificant.) I checked under the house and it has 2 inch pipe. So I figured the blockage was something like 12 feet down. I got a cheap 25 foot drum auger and was able to run the entire length through with little problem other than what I assume are corners. That's well past where it seems the blockage should be. The snake came out relatively clean with no obvious signs of any gunk. Result: no change. What am I missing here? Anything else easy I might try or is it plumber time?
