Quazi
Hi guys, I have a new vanity that I installed, and the original drain plumbing has an in line air vent installed. This shoots out the drain line to in front of the sink connector and just above it. See pics.
I want to hack of a couple of inches of the sink drain line. However, in order to get the room I need, I need to cut it to the top line in the picture. Doing that, the bottom of the sink drain will not seat all the way down in the p-trap. Is that OK? I figure it is, as the sink line is not under much pressure, and the gasket should keep the water out. However, I would like some expert opinion. Or is there a better way to do this?
You help is much appreciated!
