SilverLk4
Hi all,
I have bathrooms with single sinks that are situated back to back and share the same drain. When the water is turned on in master sink it drains and partially fills the sink in the other bathroom which then does not drain out at all. I have removed the traps , and snaked the drain. This worked for about a month or so and then happens all over again. Master bath sink drains fine. Tub, shower, and toilets drain fine as well in both baths. Any ideas? Thanks in advance!
