shutting H2O off on vacation
Discussion in 'Plumbing Forum Help and Support' started by sunliner, Mar 17, 2015.
  1. Mar 17, 2015 #1
    sunliner
    sunliner
    sunliner
    Mar 8, 2015
    21
    Might be a stupid question or two here but....
    We're going out of town for a week or so on two different occasions this year. After hearing a tale from a coworker of a leak that developed when he was out, I started shutting off my water to the house if we leave for any real length of time to minimize potential damage.
    I'm asking here what the pro's think of this practice. I've heard the 'armchair quarterbacks" say that I should not turn off water except for emergencies because it can cause problems (?) if it's turned off regularly. I don't know what those problems could be other than maybe if the water heater ran low while powered up.
    So....Water shut off while on vacation....good idea or bad?
    and should I also turn off the breaker to the water heater if I'm gone for a week, or will that breed disease and pestilence?
    thanks in advance for your time
    -Mike
  2. Mar 17, 2015 #2
    johnjh2o
    johnjh2o
    johnjh2o
    Senior Member Professional Lifetime Supporter
    Jul 21, 2011
    3,294
    756
    Melbourne, Florida
    Turn the water off at the main valve I do it myself when we go on vacation.
  3. Aug 15, 2015 #3
    StudentPlumber
    StudentPlumber
    StudentPlumber
    Aug 2, 2014
    15
    When turning your water heater off for long times you need to be carful of Legionellosis disease
  4. Aug 15, 2015 #4
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,797
    2,432
    good practice, turn off water and the gas. if, electric WH turn off breaker no since heating water not used
    when you turn off the water, open an outside faucet, it will release the pressure, drain down system
  5. Aug 15, 2015 #5
    Matt30
    Matt30
    Matt30
    Professional Professional
    Jan 17, 2012
    2,142
    827
    Halifax, Nova Scotia
    True. Just remember to run off a bit of water once the heater comes back up to temperature
  6. Aug 15, 2015 #6
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,797
    2,432
    I aint arguing
    i thought it is caused by Aerosolization, which would have to be an open system. a water heater is a closed system to arearated water
    or am i mistaken?
  7. Aug 16, 2015 #7
    KULTULZ
    KULTULZ
    KULTULZ
    Jack of All Trades ~ Master of None Professional
    Sep 4, 2011
    1,534
    316
    Between Lost And Found, W (BY GOD) V
    Just make sure electric WH is full and burped before turning power back on, correct?
  8. Aug 16, 2015 #8
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,797
    2,432
    yes, it will auto burb when you open a faucet
  9. Aug 16, 2015 #9
    donald_w
    donald_w
    donald_w
    Active Member
    Feb 16, 2015
    42
    12
    I also turn off the main water valve, but I now leave the system pressurized. When I used to open a faucet to drain the system, I always came back to my iron pipes full of rust.
    I would also suggest turning off the valves at the washing machine. I once came home to the washing machine full of water and overflowing. I suspect that the water pressure helps hold the valve on the machine itself closed, and with the pressure off, the old valve leaked (possibly also a slight drip at the main shutoff eventually filled the washer).
  10. Aug 17, 2015 #10
    steventheplumber
    steventheplumber
    steventheplumber
    Jul 10, 2015
    104
    11
    I would definitely turn of the water and gas for that matter. Better not to leave anything to chance, or have any bad thoughts while you are on vacation. This is one of those better be safe than sorry kind of things.
  11. Aug 17, 2015 #11
    KULTULZ
    KULTULZ
    KULTULZ
    Sep 4, 2011
    1,534
    316
    ...hmmph...
    Never thought of that.... THANX! ;)
  12. Aug 18, 2015 #12
    FlatRateFoxCities
    FlatRateFoxCities
    FlatRateFoxCities
    Aug 18, 2015
    6
    Appleton, WI
Draft saved Draft deleted
Share This Page
Group Builder
