Showerhead holder
Discussion in 'Showers and Tubs' started by polat2, Jan 5, 2019.
  1. Jan 10, 2019 #21
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    2,363
    406
    North Reading, Mass.
    I'm guessing that the flow restrictor for those shower/hose assemblies is likely at the end of the hose that connects to a water pipe.
    For your flow test, did you disconnect the shower head off the hose or did you disconnect the entire hose assembly? I'm thinking you may have still been going through a flow restrictor if only the shower head was removed. If that's the case, do it again. Then what you get for unrestricted flow is roughly what you could expect to get from 2 shower heads(minus a tad) connected to that same source. While you're at it, look to see if there's a removable flow restrictor(may look like a washer with a small hole in it as well as anything else that appears to be restricting the flow, and is removable.
    Were you thinking doing something like what Mikey shows in post #9 above? EDIT: (oops! Didn't realize that was a diverter and not capable of 1 in and 2 out. I guess a tee would have to be considered.)
  2. Jan 11, 2019 #22
    polat2
    polat2
    polat2
    Jan 5, 2019
    19
    nyc
    I do see a black part inside the hose and the test did go through that. However I also posted numbers for the bottom nozzle which isn't connected to any hose so would those numbers suffice?
    Yes post 9 is something I can try if it'll allow me to operate two showers simultaneously with water coming out of each of them at the same time
  3. Jan 11, 2019 #23
    polat2
    polat2
    polat2
    Jan 5, 2019
    19
    nyc
    also what 1.5gpm low pressure shower head do you recommend? I'd like to test one for a few days and see if it suits me because if I'm only getting 2.64gpm in total, then dividing by 2 is little lesser than 1.5
  4. Jan 11, 2019 #24
    Mikey
    Mikey
    Mikey
    Jul 16, 2018
    271
    47
    Northwest Washington
    I may have screwed up; most diverters just divert - they don't share. You may need to add a cross, which you might have to build yourself to match the other fittings. I'd use 1/2" PVC fittings to start with, and if things work OK, look harder for chrome.
  5. Jan 11, 2019 #25
    TomFOhio
    TomFOhio
    TomFOhio
    Professional Professional
    Jan 20, 2018
    1,035
    219
    Mansfield,, Ohio
    Are you able to run all those body sprays at one time plus the shower head?
  6. Jan 13, 2019 #26
    polat2
    polat2
    polat2
    Jan 5, 2019
    19
    nyc
    so any ideas guys if I should do this or my gpm is too low to have a satisfactory result with 2 showers running at the same time?
  7. Jan 13, 2019 #27
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    2,363
    406
    There are at least 2 parameters that must be determined to make a judgement of available flow through 2 shower heads simultaneously. Also, whether the flow restrictor can be removed from the shower assembly, which would increase the flow through the shower heads.
    One thing that will affect the available flow through 2 heads is....how it will be piped.
    For example using the existing shower valve and teeing in 2 shower head assemblies. (Assembly = 1 head and the associated flex hose.) In which case, would you just drape the hose across to the other shower holder???
    Do you plan on changing out the existing shower valve and/or do anything behind the shower walls?
    I have no idea if that bottom nozzle has a flow restriction or not.
    I was trying to get the flow available from the shower control valve, before being restricted by the devices they use to limit the flow through a shower head. And it sounds like there may very well be a restrictor in that hose connection by what you said. So as far as I am concerned, it appears that you haven't tested the flow from the shower valve without the restriction of the shower assembly.
  8. Jan 13, 2019 #28
    polat2
    polat2
    polat2
    Jan 5, 2019
    19
    nyc
    i'll try to remove the flow restrictor and test again. I checked the bottom nozzle and don't see any black part inside there so assuming there isn't a flow restrictor - thx
  9. Jan 16, 2019 #29
    SHEPLMBR
    SHEPLMBR
    SHEPLMBR
    not a Junior Member anymore! Sponsor
    Mar 9, 2016
    830
    165
    NOKESVILLE, VA
    foot wash spout
  10. Jan 20, 2019 #30
    polat2
    polat2
    polat2
    Jan 5, 2019
    19
    nyc
  11. Jan 24, 2019 #31
    polat2
    polat2
    polat2
    Jan 5, 2019
    19
    nyc
    so what do you guys think?
  12. Jan 24, 2019 #32
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    2,363
    406
    I think you should just pick up a tee and put it at either shower connection and connect your 2 existing shower assemblies and see what you get. Chances are that you will get more than 2.72gpm out of the 2 combined showers going through that tee.
    Then you can decide if it would be worth going to shower heads designed for lower flow rates.
    Personally, I have no idea what to expect out of a shower head deigned for a lesser flow.
    Whatever you do just make sure if you're running 2 heads simultaneously that you don't have any flow restrictors anywhere.
    EDIT: The shower heads designed for lesser flow may just be more restricted. Are you thinking they would perform better with a lesser pressure? I wouldn't think so. Apparently they do advertise heads that perform better on low pressure applications. What they do, other than maybe removing any flow restrictions, I wouldn't know. Less holes maybe for harder spray?
  13. Jan 24, 2019 #33
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,797
    2,432
  14. Jan 25, 2019 #34
    polat2
    polat2
    polat2
    Jan 5, 2019
    19
    nyc
    if only a single shower head is running i'm asuming it'll get the full power 2.72gpm right or do I need to get some sort of adjustable Tee to direct flow
    I may also try to replace my current shower head with a low pressure 1.5 gpm to see how i like it before doing the tee project
  15. Feb 1, 2019 #35
    polat2
    polat2
    polat2
    Jan 5, 2019
    19
    nyc
  16. Feb 2, 2019 #36
    polat2
    polat2
    polat2
    Jan 5, 2019
    19
    nyc
    Anybody? sorry been dragging this thread but want to get this done and appreciate everybody's inputs!
  17. Dec 11, 2019 #37
    jeanjean
    jeanjean
    jeanjean
    Jun 6, 2019
    5
    5801 South Ellis Avenue Chiago, Illinois
    Small and few water jet holes may be one of the reasons, but the reason for the water pressure cannot be ruled out. In addition to removing the water flow restrictor, increasing shower water pressure is another possible solution.
Draft saved Draft deleted
Share This Page
Group Builder
