shower water pipe joist routing
Discussion in 'Project Display' started by Leolibra77, Jun 24, 2017.
  1. Jun 24, 2017 #1
    Leolibra77
    Leolibra77
    Leolibra77
    Jun 12, 2017
    Hi all,
    Thanks for taking the time to read this. I started a bathroom remodel. I took out the old shower pan and walls. I saw that the water pipes were coming through the sub floor and in front of the framing. I needed to repair the sub floor by the drain anyway so cut out sub floor to the pipes to see why the builder had done it this way. So by removing the sub floor, I can see an engineered I beam joist right behind the water pipes. Probably poor planning and somebody screwed up. Anyway my question is what needs to be done in order for me to get the water pipes inside the wall framing? I am going to tile the floor using Kerdi tray. Can I notch the top edge portion of beam which sticks out about 1"? The shower is right next to outside wall portion of joist. Any other ideas to consider?
    JJ
  2. Jun 29, 2017 #2
    SHEPLMBR
    SHEPLMBR
    SHEPLMBR
    not a Junior Member anymore! Sponsor
    Mar 9, 2016
    823
    164
    NOKESVILLE, VA
    The did it that way because of the floor joist below it. The tub concealed it. Have had to do it that way before on new work because the carpenter didn't want to header the joist for free because the builder wouldn't sign a change order
  3. Jun 29, 2017 #3
    SHEPLMBR
    SHEPLMBR
    SHEPLMBR
    Mar 9, 2016
    823
    164
    NOKESVILLE, VA
    And no you cannot notch. What is on other side of joist
  4. Jun 30, 2017 #4
    Leolibra77
    Leolibra77
    Leolibra77
    Jun 12, 2017
    it is an interior wall separating master bed with bath.
  5. Jul 1, 2017 #5
    SHEPLMBR
    SHEPLMBR
    SHEPLMBR
    Mar 9, 2016
    823
    164
    NOKESVILLE, VA
    Ok so drill 2 holes through it and 90 back into the wall
    Rossando likes this.
  6. Jul 1, 2017 #6
    plumb_bob_square_pants
    Dec 20, 2015
    258
    59
    You could also find another way up that's close and just run the piping through the studs. Is there another wall that is for your shower? You could off set below and then run up into that wall and across.
Draft saved Draft deleted
Share This Page
