Captain Norm
Hey guys, new here. I'm helping my son out with a leaky shower/ broken diverter but I can't seem to find a brand, so not sure how to fix or what to replace it with. I'm sure you all will know instantly. Thanks in advance!!
Theses valves are made in Braintree ma very popular in our area most plumbers will recommend themThank you. I'm going to put a new valve in my other shower. I'll then see if the parts will fit this valve also.. Thanks for your help
Would you know the part numbers? There are a few different repair kits. Thanks for your replyThat's a summons shower valve one of theost bullet proof valves around very few parts to repair summons makes their own tools to repair the valve VERY SIMPLE ,sorry for the auto correct symmons is what I meant
Hot water tank. Thanks for the info.The stem is a ta-10
Ta-4 is the hot and cold seat
T35c is the complete wrench kit you will need
Ta-25a is the diverter cartridge
Not sure what else you need
How are you heating your water a hot water tank or a tankless coil in your boiler the stem #s are diffrent
Ok the stem number is for that, if you go thru symmons, sometimes they replace parts for freeHot water tank. Thanks for the info.
Thank youOk the stem number is for that, if you go thru symmons, sometimes they replace parts for free
