JRHH
Just converted a bath tub to a shower recently and have noticed that water is seeping up from under the grout lines on the corners of the shower closest to the shower drain. Even after you soak up all the water with a towel water continues to seep up from below and those areas never really dry between showers. I decided to pop off the shower drain cover and noticed that instead of PVC Pipe the shower drain is just a hole in the mortar shower bed that leads to the old bath tub pvc pipe drain, so the shower drain is not connected to the main line. I believe the water that is seeping up is the Water that is going down the drain and also into the mortar as it go’s down the drain. Shouldn’t there be a drain pipe from the drain cover all the way to the main drain line? Also is there a way to put a pipe in without ripping the whole floor out with a jack hammer? Has anyone ever heard of this before ?
