I am a new employee at a company, and have been tasked with figuring out a problem with a jet pump.
We have a large, underground tank, which is piped to a shallow-well jet pump (3/4 hp), which is piped to a pressure tank, then through a series of filters, then to a hotwater heater and out. They have now had a second pump burn up, because it ran continuously, and did not shut off when it was supposed to.
We discovered that the threaded pvc pipe coming out of the outlet on the pump had stripped and pulled out. I assumed that this was because the pump was not bolted down (it was just sitting on a board), and had vibrated so much that the pipe stripped out.
First, does it seem plausible that this is the reason why the pipe pulled out?
Secondly, why might the pump be continuously running and burning up? What things do I need to check?
I'm not a plumber, but I think I can follow advice in a plumbing system.
Dan
Dan
