Jeff Knecht
Good Morning,
Need to reset two toilets after bathroom remodels. I have installed a toilet maybe 6 times and have had pretty good luck. In the past, I always figured. that if the toilet leaked, the water would be visible pretty quick and I could mop up and reinstall. However, I went against the common practice/good sense of installing a tile product and instead, installed vinyl plank. Thus, if there is a slow leak, by the time I catch it, it could work its way into the subfloor and I will have to deal with that.
Is there a wax ring, that is DIYer friendly and makes more solid contact with the toilet? I usually have another person help with lining up the studs, snuggle the toilet down, and tighten the nuts down evenly on both sides but not overtighten, until there is a firm connection.
Any tried and true installation techniques would be appreciated.
