So you are saying that the reason for having to pump it was that the tank level was above the level of the exit pipe causing the flow to back up in the house?I had it pumped less than a year ago and once again is filled up. Any suggestion?
Thanks for you response Macgyver, it was very helpful. I just checked manhole where water comes from the house and by the way, I did not see a baffle on the inlet pipe as it comes from the house. It is just an inlet pipe with no tee on it. Is that a problem?
So I have to check the other end of the tank and see where the water level is and if indeed is above the outlet pipe.
