septic filtration
Garbage disposals are my best friend for stopped up lines. Lol. To answer your question, that small box was an interior grease trap ( food interceptor ) and keeps it from your lines, the down side is the stuff that accumulates is nasty, sour, rotten smelling and has to be cleaned out regularly by a pumping company. You could use a shop vac but then you have no where to get rid of contents so you are actually creating another problem. The fasted Olympic runner couldn't catch me to give me a disposal
I agree, but...
I am on septic (tank I should say)... :eek:
The only reason I have a GD is to make sure whatever goes into the drain by-passing the drain basket from washing dishes (or pre-wash before the DW) is finely ground. It is a mute subject actually as if you have a DW on septic, it too will discharge food particles, how finely ground no one knows.
It is a convenience and as long as you understand the possible results, there should be no problem.
As for grease (and soap scum buildup due to hard water) a home grease trap is available but I don't want to clean it personally... :eek:
You guys that live out too far for trask pick-up. Have you thought about a trash compactor for garbage?
I agree, but...
i have a trash compactor to. though we have a private trash company to pick our trash up and i split the cost with my neighbor and it's only 4.50 a month for me
LOL i hear you on that when you say a GD is your best friend for backed up lines :D. though i never had backed up lines in my entire life. except when i had my apt building GD'S and cast iron piping don't mix.. that and you have people that put there mother in law down em:D and expect it to grind her up:rolleyes: then your getting calls at 3 am my sinks clogged or during thanksgiving and christmas. i installed the badger 1 units wich is total crap.. i went with the evolution excel since i'll probily be in the house for a while and the thing will more than likely last a good 20 years or more. iv'e changed my mind on the food interceptor
