Schluter Linear Drain Install
Jeff Cox
Oct 16, 2021
Arizona
Can I connect the Schluter linear drain this way to 1 1/2" waste line? Thank you.
Doesn’t look like there would be anything making a water tight connection to me.
So the drain will cement into your abs.
Yeah that’s fine, shower drains are typically 2” but 1.5” will work fine for a one shower head set up.
The picture looks like you’re inserting the metal spigot of the shower drain into a 2x1.5” abs bell reducer.
What if I add a 2" piece of abs pipe to attach with the 2" X 2" flexible coupling to the linear drain and then use the 1 2" X 1/2" bell reducer? I am open to a different direction in support of the schluter 32 linear drain.
