Hi All, I'm new to this forum. Unfortunately I have an issue with the water system at my house, it has been happening for about 3 months (maybe longer). Basically there is a running water noise/vibration when the water mains is turned on. If I close the mains valve, the noise stops. In Australia, we don't have a valve between the mains and the house. I can't remember what I was doing prior to the noise starting, I suspect it was changing out the flushing mechanism of a toilet or changing out some taps on the bath.
I have done some troubleshooting:
- Checked my water meter when not using water for several hours and there was no change to the meter reading. Although I can feel the meter ticking slightly, not sure if there is a minimum flow for the meter to work?
- Isolated toilets at the wall, hot water system, evaporation air con, all the basins I can isolate with the valves prior to the taps, dishwasher, washing machine. None of these stop the noise.
- Tried bleeding the air from the house water lines with no luck.
- Checked over all the copper piping in the roof and haven't found any leaks. Although the cold water lines vibrate like there is a flow.
- No taps inside or outside are dripping.
- Done the 'dye' test on the toilets.
- No walls appear to be water damaged.
Does anyone have any suggestions other which might help? This noise is driving me bananas but I'm hesitant to call a plumber as they charged me $150 to change out 2 sink valves and a tap to the dishwasher. Can't imagine what they would charge to troubleshoot and then repair an unknown leak.
