Resevoir water
Discussion in 'General Plumbing Help' started by travis uhlmansiek, May 5, 2019.
  1. May 5, 2019 #1
    travis uhlmansiek
    travis uhlmansiek
    travis uhlmansiek
    May 5, 2019
    Utah
    I live in a community that has water, gravity fed from a local reservoir by a 6 in pipe. In the evenings I don't get water to my house for a few hrs. I have talked to my neighbors and none of them seem to be using their water and they are all having the same issues. I am planning on getting a pump hopefully to syphon the water to my house. Will this even work? What type of pump should I be looking for?
  2. May 5, 2019 #2
    Geofd
    Geofd
    Geofd
    Professional Professional
    Jan 20, 2018
    1,277
    191
    Boston, Massachusetts
    try talking to your water supplier if y our whole neighbor hood is having the same problem there a problem with the method they deliver water
  3. May 5, 2019 #3
    travis uhlmansiek
    travis uhlmansiek
    travis uhlmansiek
    May 5, 2019
    Utah
    It's a private resivoir, no one in is in charge of it. Since it works most of the time, I am trying to find a way to make it more reliable. That's why I was thinking a pump. I believe someone is using a lot of the water, and they just aren't fessing up to it.
  4. May 5, 2019 #4
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    1,277
    191
    thats probably the way to go how do you know the quality of the water???? if no one controls it
  5. May 5, 2019 #5
    travis uhlmansiek
    travis uhlmansiek
    travis uhlmansiek
    May 5, 2019
    Utah
    Its fed by 3 mountain spring and as far as I know, no one has had an issue with it in 150 yrs. What type of pump would you suggest?
  6. May 5, 2019 #6
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    1,277
    191
    it would be best to talk to a pump company and explain your situation
  7. May 6, 2019 #7
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    1,338
    238
    North Reading, Mass.
    I agree with above comment.
    There is a lot of information that must be known and considered to size and select the proper pump.
    I would investigate into the reason this is happening. For example, does the water level drop below the inlet pipe?
    Maybe you should consider your own water tank and pump for your own needs. So you would always have a reserve of water.
  8. May 6, 2019 #8
    Matt30
    Matt30
    Matt30
    Jan 17, 2012
    2,083
    807
    Halifax, Nova Scotia
    The issue must be determined as to why you’re losing water.
    All I can think of that might work would be a booster pump, something like the Grundfos Scala 2.
    If you’re losing water because there isn’t sufficient quantity to satisfy the demand, then you’re outta luck. But if it’s an issue of just losing all pressure, then a booster pump could help.
  9. May 6, 2019 #9
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    1,338
    238
    If you are not getting any water at all for a period of time, there's always a possibility that the piping is such that another user is using all the available water due to their proximity and path of least resistance.
    I'd get my own tank and small pump and let it fill when water is available and just size it for those down times. End of problem.
  10. May 6, 2019 #10
    RenewDave
    RenewDave
    RenewDave
    Feb 18, 2018
    204
    38
    If you lose water(not just pressure) a pump really won’t do much, except maybe burn out. The best way would be to add a cistern and then pump out of that. Addressing the main supply problem would be money better spent if everyone is having the same problem.
  11. May 7, 2019 #11
    FishScreener
    FishScreener
    FishScreener
    Aug 23, 2018
    253
    67
    83467
    First guess is that the cistern is undersized, and in the afternoon/evening, you’re neighborhood is emptying the cistern. And, nobody gets water. So, everybody shuts down for a bit, and the system has a chance to catch up. Then it refills overnight, and lasts most of the day.
  12. May 7, 2019 #12
    travis uhlmansiek
    travis uhlmansiek
    travis uhlmansiek
    May 5, 2019
    Utah
    The resovoir is roughly 50,000 gallons. More than enough for the 20 houses. I am at the far end of the line and figure the demand is to much for the water line and is the reason I don't get water. I am hoping a hoping a pump would syphon the water to me instead of diverting to my neighbnors lines
  13. May 7, 2019 #13
    RenewDave
    RenewDave
    RenewDave
    Feb 18, 2018
    204
    38
  14. May 8, 2019 #14
    chiraldude
    chiraldude
    chiraldude
    Hardcore DYI-er
    Nov 16, 2013
    121
    26
    Southern Minnesota
    You and your neighbors are very lucky this system has lasted as long as it has. I would say you are on borrowed time.
    Someone in your community needs to be "in charge" of the water system. That person needs to do the following (or pay a contractor to do it)
    1. Monitor the level in the reservoir and/or measure the inflow from the springs. You need to find out if usage has increased or if inflow has decreased.
    2. Determine the condition of the reservoir and delivery pipe. Is it clogged or crushed? Is there a leak? A camera inspection of the reservoir and entire length of pipe would be a good start.
    3. Have the water tested for safety. Probably fine for minerals but bacteria should be checked once a year at least.
    My concern for you is that you are the only one taking initivae on this. If the main delivery pipe is failing or the reservoir has a huge leak, you won't be able to pay for it yourself. If you don't have a formal association, you will end up knocking on doors begging people to contribute to the repair fund. If there is an issue with specific users, you could have a big problem if they won't cooperate. You have no means (legal or otherwise) of cutting off an abusive user for example.
  15. May 10, 2019 #15
    wood4d
    wood4d
    wood4d
    Apr 1, 2014
    93
    13
    I think a 50,000 gal resevoir is a 12 x 12 hole about 10' deep
  16. May 10, 2019 #16
    RenewDave
    RenewDave
    RenewDave
    Feb 18, 2018
    204
    38
    12x12x10x7.48= 10,771.2 I think you’d need a hole 25x25x10 to be close to 50k gallons.
  17. May 10, 2019 #17
    edfiero
    edfiero
    edfiero
    Oct 5, 2015
    18
    I agree with chiraldude. If you don't already have it, you need an association where you can collect 10 bucks a month or something from each person and establish a fund to perform repairs on the reservoir and distribution system when needed. And as other have said you need to determine if the problem is low water in the reservoir or an issue with the delivery system that becomes more obvious in the evening when the demand might be higher.
Share This Page
