Daniel Vale
Greetings,
I'm replacing a tub/shower assembly with a shower-only, using a Sterling acrylic base, left-side drain. Not sure how to proceed with modifying the existing waste-water plumbing for the needs of the shower base. I hope it's as simple as cutting off the minimum necessary, then re-plumbing up to the location of the pan drain-hole. Thanks in advance...
