replacing frozen CPVC ball valve, need HELP!
Call a pro!
The critical step is to not cut off all the water in your building for several days, and get fined by the association for it.
And then have to pay a plumber bigger money because he knows you are desperate, and because you already screwed up what little pipe he has to work with.
If it were me, I would cut the valve out, cut into wall if necessary.
Then begin with a CPVC x 3/4" threaded adapter (the kind with the brass threads). Then build it all back with propress as needed.
Simple and bomb proof. Done!
