Hello,
My problem is as the title says. The diverter isn't working anymore and the hand shower hose is broken. Here are some images of the faucet.
1) What do you even call this? I've seen "5 hole, deck mounted, roman tub faucet" and "triple handle, deck mounted, roman tub faucet". Or is that wrong too?
2) What am I working with? Is it Delta, or Moen, or something else? I've looked for brand markings and can't find any.
3) How do I replace the hand shower? I thought that the cover/knob thing on the far right that keeps the hose retained would screw off/pull off so you can get the hose and shower head out but that doesn't work (grabbed it with pliers and it just kept spinning without getting any tighter or looser). I can't see a set screw either so I'm not sure what to do (cut the cover/knob? start smashing tiles?).
4) How do I replace the diverter? So the handle on the left screws off and then there's a nut under that, that I imagine holds the diverter valve in place. So, undo the nut then the diverter valve should pull right out, right? I think this one makes sense but it ties back into 2 because if I know what I'm working with then I can get a replacement part.
Hope you guys can help point me in the right direction with this stuff.
Thanks.
Thanks.
