Replaced Pedestal Sink with Vanity
DIY Noob
Aug 5, 2019
Missouri
I just replaced a pedestal sink with a vanity and sink. The new sink drain is slightly further from the wall than the pedestal drain was. I'm not entirely sure how to go about attaching the P-trap without opening the wall and redoing the existing pipe work, but even then I wouldn't know what I'm doing. I assume I could cut the existing schedule 40 and insert a tee, then connect a trap adapter. I've attached a photo of the existing pipe. Please advise if I'm on the right track or if there is an easier way to do this that does not involve tearing into the wall.
Thank you.
if that fitting at the wall is a ty is it 2"???? if so you could use a (ram bit) it drills out the pvc pipe glued into the fitting if its 1 1/2" just use regular pvc/and pvc trap
It does appear to be 2". I was unaware of ram bits, but it seems like a good option. I appreciate the advice.
Thank you.
