Removing Faucet or removing cap,, Please HELP !
Discussion in 'Toilets and Sinks' started by Lui, Jul 10, 2019.
  1. Jul 10, 2019 #1
    Lui
    Lui
    Lui
    Jul 10, 2019
    Montreal
    Hello everyone,
    Need some help here.
    My faucet (unknown brand) has been leaking and in need of changing the cartilage inside.
    I can't seem to remove the faucet cap with an allen key, I've tried both metric and inches tools. Am i missing something here ?
    I can't remove the faucet itself either as the contractor who installed it seems to have blocked the bolts.
    Please see pictures and let me know what to do. I am not very handy btw unfortunately
    Thanks
    L
  2. Jul 10, 2019 #2
    Geofd
    Geofd
    Geofd
    Professional Professional
    Jan 20, 2018
    1,355
    203
    Boston, Massachusetts
    I have drilled out the allen screw before but its a delicate procedure you may ruin the piece that's attached to the handle sometimes the brand name is on the body of the faucet facing you or its on the drain assembly you also may be able to use a small easy out and remove it that way
  3. Jul 10, 2019 #3
    havasu
    havasu
    havasu
    Jan 6, 2010
    9,278
    1,294
    Southern California,
    415dxe6YnPL._AC_SY400_.jpg EZ Outs will remove the stripped Allen likity split. They have a square shank that cuts in when reversing.
  4. Jul 11, 2019 #4
    Lui
    Lui
    Lui
    Jul 10, 2019
    Montreal
    Hi @havasu
    Hi @Geofd
    Thank you for the messages, i went this morning and bought the Ez Outs but unfortunately it didn't work, maybe im not using it properly but I couldnt figure it out, Any other ways ?
    Thanks again
    L
  5. Jul 11, 2019 #5
    havasu
    havasu
    havasu
    Jan 6, 2010
    9,278
    1,294
    Did you use a hammer to tap it in snug? If so, time to drill it out.
  6. Jul 11, 2019 #6
    House Doc
    House Doc
    House Doc
    "If it's broken we fix it
    Jan 6, 2010
    36
    17
    Southern Cal..by way of Chicago area
    I've posted this a few times
    When I run into a stripped allen screw I will try and find a Torx bit that's close and tap it (gently) into the hole. The flutes on the bit will cut into the set screw and you can usually back it out. First I give it a little blast of PB Blaster, one of the best rust/corrosion products I've found.
    havasu likes this.
  7. Jul 12, 2019 #7
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    15
    Chicago
    House Doc has it right, a slightly oversize Torx bit.
    Also, if the Torx wrench is still not grabbing, maintain good force in towards the screw, but also give the wrench shaft a little sideways push, while trying to twist out the screw.
    So the bit is grabbing better on one side of the stripped set screw socket.
  8. Jul 12, 2019 #8
    havasu
    havasu
    havasu
    Jan 6, 2010
    9,278
    1,294
    Are you 100% sure the set screw is still in there? I'd attempt PB blaster overnight, then pull up forcefully.
  9. Jul 12, 2019 #9
    Mikey
    Mikey
    Mikey
    Well-Known Member Supporting Member
    Jul 16, 2018
    232
    37
    Northwest Washington
    And if you use a reverse drill bit your odds get a little better.
  10. Jul 14, 2019 at 5:09 PM #10
    Lui
    Lui
    Lui
    Jul 10, 2019
    Montreal
    Thank you for the answers,
    I am not sure what is happening with the faucet. I am assuming there is a screw since the faucet is not coming out, but for some reason the Ez Out isnt grabbing into anything and neither the Allen keys @havasu, @House Doc @Jeff Handy
    I am not sure what the other options where to remove it @Mikey with the blaster (First diy at home) ..
    I was thinking of removing the whole faucet and taking it to the store to either fully replace or remove the cartilage. Based on the pic of the underneath and the videos i watch i think thats not possible, i would have to get a thin tool to try to twist it from top ??
    thanks again
  11. Jul 14, 2019 at 5:25 PM #11
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    1,355
    203
    have you tried a small flat head or small phillips….maybe its one of those
  12. Jul 15, 2019 at 12:45 AM #12
    havasu
    havasu
    havasu
    Jan 6, 2010
    9,278
    1,294
    When in doubt, use a sawzall, cut the damn faucet out, and install a replacement.
  13. Jul 15, 2019 at 2:31 PM #13
    Mikey
    Mikey
    Mikey
    Jul 16, 2018
    232
    37
    I think @havasu is onto something. I'll bet someone in the past actually removed the screw, he coudn't get the thing off either and gave up. Can you get some kind of puller in there? Maybe make one to straddle the faucet and pull from both sides?
Share This Page
