Quantcast
Remote controlled residential water shut-off system
Brooklin
Jun 21, 2018
Brooklin, Ontario
I am looking for a 'kit' that I can purchase for installation in my main water supply line that includes a sol. operated shut-off valve that I can open & close from a remote mounted switch conveniently installed along side my home security panel. This forms the basics of my wants & I am sure there will be other devices required to make this a functional system. I appreciate that there are numerous systems available on-line but my preference is for a basic unit, manually controllable & not reliant on bells & whistles to sense water leaks. If you are aware of a source I would greatly appreciate your letting me know. Thank-you. Stay safe.
Twowaxhack
Feb 9, 2021
738
238
United states
I’ve done this before with a Parker normally open 1” solenoid.
Im sure there are more economical options.
breplum
Professional
Professional
Nov 14, 2017
884
368
Lafayette, CA
Phyn is one brand. Outrageously priced imho.
A fairly new one went kaput after a few months and the company sent out a replacement but my customer still had to pay for my labor.
Not very nice to install because power is a puck then low v. to the unit. Nobody has 120V near service entrance outdoors around here...and wait until hell freezes over because, like in texas, we have pipes (and this unit) exposed at the front of the mansion.
RS
Dec 25, 2019
149
41
USA
Unless you have very high pressure I would think a sprinkler zone valve would work, unless there's some reason you aren't supposed to use them for potable water.
Twowaxhack
Feb 9, 2021
738
238
United states
Sprinkler zone valves require power to stay open. They’re not rated for continuous duty. Not to mention if the power goes out you lose water too....
The best option is a motorized ball valve. It only uses power when it’s actually being turned on off.
Brooklin
Jun 21, 2018
Brooklin, Ontario
Brooklin
Jun 21, 2018
Brooklin, Ontario
Greatly appreciate the feedback from all of you. As previously indicated I much prefer to have a basic set-up for this purpose, not something with all the bell's & whistle's as they tend to breakdown when needed most. I plan on installing a ball valve, upstream from the existing Gate valve & installing a motorized actuator to physically open & close same on demand. I will install a selector switch along side the home security panel & when we leave the property we will select 'close', set the alarm & be happy. Not 24 hr. coverage but when used at night & when not at home it does come close to what I believe to be adequate.
Thanks again, Brooklin...
Mitchell-DIY-Guy
Oct 16, 2019
407
138
North Carolina
If you are going to consider something like that you probably want a "motorized ball valve" not a solenoid. Ensure that it's a full flow for the pipe size; if not, go up in size and use adapters. You don't want the unit impeding any flow. Do a search and you'll find plenty.
Most of them I've seen had a spring return, so you had to decide if you wanted normally open or normally closed, and whether 24VAC or 110.
