Recirculating Pump or Point of Use tank?
Discussion in 'General Plumbing Help' started by bowens, Jun 6, 2019.
  1. Jun 7, 2019 #21
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    1,384
    242
    North Reading, Mass.
    That's not what RenewDave said. He made a correct analogy to, "The energy loss/use issue seems like a non-issue."
    You're saying that the usable capacity of the 2.5 gal heater is not sufficient while the one gallon of cold water is entering it. Granted it has a rather small recovery rate but the amount of stored water at X temperature must be considered as well.
  2. Jun 7, 2019 #22
    Mikey
    Mikey
    Mikey
    Well-Known Member Supporting Member
    Jul 16, 2018
    232
    37
    Northwest Washington
    And, as the POU tank draws in new water, if it draws from the hot line, you will have the hot line full of hot water (eventually), which will slowly cool off when the water use stops. Same heat-loss issue as with the on-demand circulator, as far as I can see. Only way to eliminate that is to draw from the cold supply, and you will have 2.5 gal of hot water ready... eventually. Rinse, lather, repeat.
  3. Jun 7, 2019 #23
    RenewDave
    RenewDave
    RenewDave
    Feb 18, 2018
    216
    41
    Soooo many negatives in that senecio. And one more, the tank will only help(marginally) the kitchen. The recirc pump could improve the entire hot system.
  4. Jun 7, 2019 #24
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,400
    2,312
    i disagree on my circ line
    I am turning on the pump. with the light switch. this gives the pump the time to return the water that has cooled to the water heater and replace it with hot water
    or am i missing somthing?
  5. Jun 7, 2019 #25
    RenewDave
    RenewDave
    RenewDave
    Feb 18, 2018
    216
    41
    I’m not clear on your post.
  6. Jun 7, 2019 #26
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,400
    2,312
    ok...you have a dedicated line from the water heater to the kitchen sink
    with another line beside it as a circ line
    this line will go cold from no use
    when the pump is told to come on it pumps hot water to the ks
    we are talking 30' of 1/2'' pipe. I think that is less than a 1/2 gallon
    a taco pump that moves 300 gpm will have hot water to the sink in a second [literally]
    the pump is wired to the kitchen light switch. turn on the light and open the hot valve
  7. Jun 7, 2019 #27
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    1,384
    242
    LOL...You're both talking a recirc line. It's just the matter of controls now.
  8. Jun 7, 2019 #28
    RenewDave
    RenewDave
    RenewDave
    Feb 18, 2018
    216
    41
    Right, that’s why I like a recirc with a timer. You can “fine tune” your demand with your use cycles. We are all pretty much creatures of habit.
  9. Jun 7, 2019 #29
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,400
    2,312
    hey...timer or switch. makes no diff to me. that is a home owner preference not a frodo preference
  10. Jun 7, 2019 #30
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    1,384
    242
    I prefer the advantages of using all three together. Timer/Temp Sensor/Manual Switch.
  11. Jun 7, 2019 #31
    bowens
    bowens
    bowens
    Jun 6, 2019
    22
    California, east bay of San Francisco
    I would expect a switching valve to be involved, but I haven't got that far yet. And I would think that storing/heating a 2.5g insulated tank is more efficient than what's in the copper pipe.
  12. Jun 7, 2019 #32
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,400
    2,312
    please explain how using electricity to keep cycle a heating element on/off
    24/7 to keep 2 1/2 gallons hot will be more efficient than running a pump only when the water is needed.
    now, to address the ''water in the pipe''
    the pipe is also insulated like the tank..
    and that water returns to the hot water tank
    lemmie see...30' of 1/2'' copper pipe holds .36 gallon that is negligible
  13. Jun 7, 2019 #33
    bowens
    bowens
    bowens
    Jun 6, 2019
    22
    1) running the pump only when hot is needed means waiting for a gallon+ of cold to arrive (and the pipe is 3/4 for some length of the 40 feet).
    2) I doubt that the pipe can be insulated as well as the small tank.
    2a) I've only heard the main tank's heat pump running after I've used a few gallons or more of hot water, so it must be pretty well insulated.
    I think this is a "six of one, half dozen of the other" situation, with regards to the heat loss.
  14. Jun 8, 2019 #34
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,400
    2,312
    1] running the pump only when hot is needed means waiting for a gallon+ of cold to arrive (and the pipe is 3/4 for some length of the 40 feet).
    I agree....silly argument
    3/4 copper @40' = .918 gallon
    ......a taco water heating circ pump
    .....1/25 HP pumps 16 gpm
    .....it takes 3.75 seconds to pump the water in the pipe 40'
    We seem to have a misunderstanding on the cold water in the pipe,
    It DOES NOT come out the faucet.
    It returns to the water heater in 3.75 seconds when pump is turned on.
    see drawing
    I agree with Dave about the SAMMICH
  15. Jun 8, 2019 #35
    bowens
    bowens
    bowens
    Jun 6, 2019
    22
    there's something I'm not understanding, I guess
  16. Jun 8, 2019 #36
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,400
    2,312
    and that something is?
  17. Jun 8, 2019 #37
    bowens
    bowens
    bowens
    Jun 6, 2019
    22
    if I knew...then I would know!
  18. Jun 8, 2019 #38
    bowens
    bowens
    bowens
    Jun 6, 2019
    22
    First, take the switch thing off the table (personal preference; I don't want to have to school visitors on how to get hot water).
    baby steps...with no pump switch, what keeps the cold water from coming out of the faucet when demand is initiated?
  19. Jun 8, 2019 #39
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,400
    2,312
    I am so so so sorry that your visitors are people with serious vision problems
    my condolences :p sarc/ people usually do not need instructions to turn on the light to see:rolleyes:
    1]with out a switch to tell communicate with the pump, you will not have the energy saving option
    of using power only when you want hot water
    2] You would still have an energy saving option, with a timer
    example... pump on at 7am...off at 9am while you are working it is off
    back on at 5pm etc
    most of us have predictable schedules
    3] an aqua stat, a sensor on the pipe that reads the temperature, and tells the pump when to come on to keep that temperature
    anything that turns the pump on, will also remove the cold water from the pipe in 3.75 seconds
    also..a check valve is installed on the cold water heater feed where the return circ line ties back into the tank
  20. Jun 8, 2019 #40
    RenewDave
    RenewDave
    RenewDave
    Feb 18, 2018
    216
    41
    Have we all “jumped the shark” here? A pump with a timer will always be more efficient than a tank running 24/7. Just make a friggin decision and be done with it. We aren’t curing cancer here.
    Diehard likes this.
Share This Page
