Quick fix for broken sink drain Pipe/p trap
looq
Jul 29, 2020
New Jersey
Hi,
I am looking for a quick and dirty fix for this broken pvc, It is connected to a Tee inside the wall that goes to the sewer and the sewer vent
Take a hack saw blade. Cut through just the broken pipe. Then, cut another slice, about 1/4 of an inch away, only thru the broken pipe, then pop out the segment of broken pipe using a flathead screwdriver. This relieves pressure and you can carefully chisel the broken piece away from the wall. Once out, do a quick sanding to remove the remainder of the glue, and prime and glue in a new pipe. They also have power reamers if you have a steady hand.
There is also what’s called a ram bit it goes on the end of a drill and drills out the pvc in the fitting, gotta cut the remaining pvc basically flush to the fitting , in you case you could use a string saw, it works in friction
Or you can use havasu’s method
Quick and dirty, just put on a coupling like this to connect both pieces.
The big end will fit over the hub of the tee in the wall.
You might have to remove a little more drywall, to get a small adjustable wrench in there to tighten the clamp inside the wall.
This is a poor and lazy repair, but it should be watertight.
Be sure to push the broken pipe back to where it touches the piece it broke off of.
2 in. x 1-1/2 in. PVC Flexible Reducing Coupling with Stainless Steel Clamps
https://www.homedepot.com/p/305473565
