romeobravo320
Active Member
How do you measure PVC for drain fittings that will be glued? I noticed that my dry fit measurements came up short, I'm guessing because the cement and primer allowed the fitting to go in further. So do you measure from about 1/2 way into the connection or from the entire collar of the connections?
