AdamW
I'm thinking that my residential well pump has gone bad but I'm looking for some confirmation.
I've read a ton of posts about similar issues but really can't put my finger on it as a definite.
I bought my house about 3 years ago. The well and equipment were all installed (new well drilled) brand new about 6 months prior and had never been used (house had been empty about 4 years before that, no clue why they moved the well).
Today my washer gets a No Flow error and lo and behold there's no water in the faucet either. I check the water "stuff" in the basement.
My setup is a well control box and a "pump protector" connected to a pressure valve at the foot of the tank. When I reset the protector or toggle the breaker the system kicks in and pumps for about 10 seconds then the pump protector shuts it all down.
Here is the hardware:
So I'm really looking for someone who knows much better than I and might lead me in the right direction if my assessment of a bad pump isn't accurate.
EDIT: Noting that we've had about 6" of rain above normal for this month and above normal rainfall all year long so I'm confident the well is not lacking any water.
- Coyote Pump Protector
- Franklin Electric Pump Control box
- Presumably a Franklin Electric pump but I can find no documentation on what pump is installed
- "Pump set at 580' "
- "1 1/2 HP"
- "7 GPM"
- "1" Rigid"
- Pump only pumps up to about 40 psi before pump protector shut down.
- Resetting and continuing to pump more seems to only move psi needle slightly before shutting down again.
- If I hook up a hose to the drain line and turn on the pump (drain into sump pit) then pump will happily keep on pumping without shutdown, presumably because there's no pressure buildup.
- The pressure valve on the tank stays in the on position because hi-pressure has not been attained (about 60 psi)
- Pulls a consistent 235 volts
- Pulls about 14 or 15 amps before suddenly jumping to 17. This is where the protector kills the power immediately.
