HumbleDeer
Hi!
A long time ago, we had a DAB pump with a vat on it that started leaking. The motor's pump housing seals were broken and this caused the motor to get drowned and burn out. This pump was self priming, though took a long while to do so.
My mum (who's house it is) bought a new pump that has automatic dry run shutoff. This is a huge plus, except for when you want the pump to self prime. The well's source pipe is about six meters below the pump's entrance. This means the pump's self-protection kicks in before it can prime. The pump used to be hooked up to the house's failoversystem, but due to neglect this is no longer an option. The pump is meant to be used as a garden watering pump now.
My idea: A checkvalve!
My problem: I cannot get to the pump line's end.
My proposed solution: Add a T, a fill spout, and a check valve at the upper end of the pump source line. The check valve will stop air from getting in, the fill spout will allow me to prime the line with water from elsewhere.
My question: Is this generally frowned upon? How good can the check valve work when it's so far up? Will it adequately stop air from getting in even if the pump isn't used daily? Do you have any better ideas?
Please do keep in mind, I am just a 19 year old, rather weak girl doing these things. I like tinkering, but I'm not a huge daredevil or strong person.
As an extra, I am intending to add a four amp breaker and RCD inside the house where the power goes to outside, as this pump's sockets had issues with leaking water in the past. This should be fixed, but I want to be sure!
