kevin hunt
Hi All.
Recently had to have a rush replacement of a Bradford White WH under warranty for a main tank leak.
The install tech told me I had to also must have the expansion tank replaced as well as the PRV. Both the WH and tank as well as pressure reducing valve on the incoming main were done in 2012.
They wanted 1300.00 total for a remove, replace and reinstall of everything despite the fact that it was still under warranty. This is a company I haven't used in years as they are big time over-charging for services in general and have turned the upsell into a fine art. I now use another company that is far far more reasonable in how the charge for work. The reason I called in the original company is they were the initial install company and what with the warranty and all I didn't want to run into trouble with the claim.
Long and short of it is I told him forget the PRV replacement and just get me back up and running.
Charged 325.00 for the expansion tank swap (I think that crazy high) and a couple of hundred more for permit fees and the wholesaler charge for the swap of tanks. 675.00 all in but I was up against the wall with a family without hot water. But, I'll be damned if I'm gonna give him 625.00 more for the PRV itself and 12 turns of an adjustable wrench. This is a guy who wanted 485 for a back-flow preventer for the furnace water supply on a job he was already in the building for and wanted 600 for a run-start capacitor install on a single central air unit that was working but his tech thought "looked old and should be replaced"
Incoming pressure is 100psi from city supply at the moment. So the PRV probably is bad. It appears to simply be a threaded union so it's not difficult to replace near as I can tell. Here is my question;
With the expansion tank presumably pressurized at a few PSI below my current 100psi supply on the bad PRV what happens if I swap out the bad PRV and dial it down to the recommended max of 80psi.
How do I, or do I need to, adjust set pressure in the expansion tank to around 78psi?
