John Gratton
I have a 10,000 gallon catchment tank located about 150 ft from a 1 hp shallow well jet pump. The pump has an attached pressure switch.
It's all new construction.
I wanted the preasure tank for the system mounted about 30 ft from the pump but when the plumber tried this configuration the pump wouldn't shut off when it reached preasure. The pressure gauge at the pump showed wild fluctuations of pressure, so it seemed the pump kept seeing a brief low pressure and switching back on for just a short burst, then switching off, then on... To fix this this the plumber moved the pressure tank under the deck next to the pump. That took care of the pump not shutting off, but now I have to get a smaller tank that will fit in the space where the pump is located.
My question is, is there something that can be put between the pump and the tank to keep these pressure fluctuations from getting back to the pump? Is this water hammer? Would an inline water hammer suppression device take care of the problem?
It seems to me these tanks are meant to be placed far from the pump. Take the case of a regular well, the pump is down a big hole, maybe 300 ft from the tank.
Thanks in advance for any help...
