Plunger piece of drain rod stuck
Discussion in 'Drain and Sewer Cleaning' started by enmotion, Mar 6, 2018.
  1. Mar 6, 2018 #1
    enmotion
    enmotion
    enmotion
    Mar 6, 2018
    The plunger piece of drain rod got stuck on it's own when taking out drain rods.
    It's about 2.5 rod lengths down. Is there any accessory or tip anyone knows that could retrieve it? I tried using the scraper to go past and pull it back, but couldn't get it to work. Any tips appreciated.
  2. Mar 6, 2018 #2
    TomFOhio
    TomFOhio
    TomFOhio
    Professional Professional
    Jan 20, 2018
    440
    86
    Mansfield,, Ohio
    I'm not sure what you mean by drain rod.
  3. Mar 6, 2018 #3
    enmotion
    enmotion
    enmotion
    Mar 6, 2018
    Also called sewer rod. Attached a pic.
    The disc is the part I think is still down there
  4. Mar 7, 2018 #4
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    431
    57
    Boston, Massachusetts
    never see that are you trying to clear a drain...is that a small sectional
    drain cleaner?????
  5. Mar 7, 2018 #5
    havasu
    havasu
    havasu
    Jan 6, 2010
    9,048
    1,208
    Southern California,
    It looks like a gun cleaning rod for an awful large barrel gun!
  6. Mar 7, 2018 #6
    Rickyman
    Rickyman
    Rickyman
    Active Member
    Feb 5, 2018
    33
    He’s probably in a different country
  7. Mar 7, 2018 #7
    havasu
    havasu
    havasu
    Jan 6, 2010
    9,048
    1,208
    Rickyman likes this.
  8. Mar 7, 2018 #8
    EvanRojas
    EvanRojas
    EvanRojas
    Mar 6, 2018
    New Jersey, North New Jersey
    The main cause of rods becoming detached during the drain clearing process is that they simply unthread themselves, the rods purchased at the large DIY houses and builders merchants screw together and all that thrashing about in the drain can cause the rods to spin and undo.
  9. Mar 7, 2018 #9
    TomFOhio
    TomFOhio
    TomFOhio
    Jan 20, 2018
    440
    86
    Mansfield,, Ohio
    EnMotion, I hope you can get to your drain pipe. If the rods are popular over there hopefully a drain cleaning company will have a retriever. If not then the piping will probably have to be replaced . Next time use a regular electric snake, they work better.
  10. Mar 12, 2018 #10
    EvanRojas
    EvanRojas
    EvanRojas
    Mar 6, 2018
    Use the double screw end – sounds like you have simply hit the fat/soap blockage. You have to screw through the break it up.
  11. Mar 12, 2018 #11
    safaristew
    safaristew
    safaristew
    Mar 11, 2018
    Hi i have used a high pressure water jetter and a root ranger nozzle to retrieve them and rods for some plumbers hope this helps
Share This Page
