Plumblife
SHEPLMBR
She-Plmbr River Rat
Professional
Sponsor
Mar 9, 2016
1,638
576
Augusta WV
@Jeff Handy , what you suggested is the best alternative I can find on the internet. Thank you.
@SHEPLMBR , Any building 4+ floors must only have cast iron in any floor penetrations, wall rough & above ceiling. Anything non flammable is permitted. It’s actually fire codes before plumbing. Cast iron porcelain coated floor sinks are used in these cases.
I would use the plastic floor sink for any light commercial buildings. Thank you.
Zurn and watts makes them in porcelien
SHEPLMBR
She-Plmbr River Rat
Professional
Sponsor
Mar 9, 2016
1,638
576
Augusta WV
And that doesn't look like a floor penetration. It looks like it is above floor.
matt.mena
Supporting Member
Feb 12, 2021
248
183
Charlotte
My dad is a shop manager of a big rig repair and frame straightening company. Only a couple shops around the country can bend semi and dump truck frames. They got creative with the restroom.
Jeff Handy
Jul 5, 2019
4,678
1,629
Chicago suburbs
Hamberg
Professional
Professional
Supporting Member
Jan 12, 2019
366
228
Horsham PA
Leaf spring holding up the stall and a coil spring holding up the rim for the basin - nice! And they went with the "Rose" colored fixtures - bold statement
OHHH AND, the kidney-stone grab-bar on the urinal - sweet
And then there's the plastic p-traps...
matt.mena
Supporting Member
Feb 12, 2021
248
183
Charlotte
So I get an upfit job on the 14th floor of this newly built high rise. I ask my novice helper to cut the copper 1-1/4” water column stub out and install an 1-1/4”x 3/4” copper tee and 1-1/4” cap. I had to get more material and would be back. I get a call, “Hey Matt, I was cutting the copper and heard a pop and now water is dripping on the pressure side of the valve?” “What? The solder joint is leaking? Huh.”
I contact the building engineer to schedule a water column shut down to repair the base building 1-1/4” valve. That night came and I was stunned at what I cut out.
The stub out side of the valve was made up 3/8 of an inch!
The pressure side of the valve was made up only 1/4 of an inch!
Man! I’m so glad that didn’t burst with my helpers hands on it. Probably would have scared him off the ladder! Would have caused a multi floor flood as well. It’s crazy how well 1/4” of solder holds.
Twowaxhack
Professional
Professional
Feb 9, 2021
9,275
4,089
United states
Plumbing pressure isn’t much in the piping world. I tested some 1/2” type L soft and it held a few thousand pounds before it burst in the pipe wall not the joint.
Great pics, thanks for posting them
