Plumbing inspection failed
directtv
Aug 23, 2021
10
Atlanta
Hello friends am new to this forum and no idea about plumbing.Reason am here is am finishing my basement and completed all the roughing and scheduled inspections.
Plumbing inspection failed with below note
“Pressure and pipe fittings to horizontal 712”
Pipe is schedule 40 rated 240psi clearly visible am not sure about fittings attaching the pic
I need help in identifying if fittings are pressure rated or not
This pipe connects to sump pump
Twowaxhack
Professional
Professional
Feb 9, 2021
4,343
1,908
United states
The fittings you have there are not for pressure. They’re DWV fittings.
Please label the orientation of your pic. Is that looking up at the pipe ? Is the pipe horizontal or vertical? Looking down at the pipe ?
directtv
Aug 23, 2021
10
Atlanta
More info this pipe connects to sump
Looking up to the pipe, horizontal
Twowaxhack
Professional
Professional
Feb 9, 2021
4,343
1,908
United states
Hamberg
Professional
Professional
Jan 12, 2019
134
88
Horsham PA
From the pics it appears you are pumping the sump into the (sanitary) sewer?!? Huge NO-NO in PA & NJ. Schedule 40 is rated way over any (household) sump pump (1/4hp - 20psi - 3/4HP - 80psi) - I can't imagine that is what he's failing it for.
Twowaxhack
Professional
Professional
Feb 9, 2021
4,343
1,908
United states
I guess he wants pressure fittings on the discharge.
We can’t pump ground water into the sewer here either, they have to treat that water. 🤫
directtv
Aug 23, 2021
10
Atlanta
Thats right inspector is fine with pipe he is just looking for pressure fittings you can see my first post with inspector comments.
Twowaxhack
Professional
Professional
Feb 9, 2021
4,343
1,908
United states
Hamberg and I would like to know what your inspector says about you pumping ground water into the sewer.
Hamberg
Professional
Professional
Jan 12, 2019
134
88
Horsham PA
Seems odd they would care about using a "high pressure" rated fitting and not spec the type of cement/weld being used?
Hamberg
Professional
Professional
Jan 12, 2019
134
88
Horsham PA
He is fine otherwise he should have objected by now.
Welllllllll, he's not being specific with what he's failing you for (I'm assuming you asked for details?)
“Pressure and pipe fittings to horizontal 712” is referring to the IPC (Sumps & Ejectors) quick look, it doesn't appear using a S40 fitting would be a problem!?
Also, making the assumption the flow is bottom to top in the last pic?
Also, also,
Twowaxhack
Professional
Professional
Feb 9, 2021
4,343
1,908
United states
It’s not discharging into a wye fitting that’s turned up to the top of the pipe. . The OP has it on its side.
Section : 712.3.5
directtv
Aug 23, 2021
10
Atlanta
Also, also,
Yes I asked him what is the particular reason he said pipe is fine as it is rated for 240 psi fittings are not for pressure and they need to be replaced everything else is fine as this is 3rd inspection.
directtv
Aug 23, 2021
10
Atlanta
Section : 712.3.5
Yeah I
Also, also,
thats right bottom to top and I think he is looking for the wye should be turned up instead of horizontal
