Plumber's Problems
Discussion in 'Plumbing Tools and Equipment' started by question, Sep 2, 2015.
  1. Aug 9, 2018 #21
    anticlmatic
    anticlmatic
    anticlmatic
    Active Member
    Jul 24, 2018
    44
    12
    Michigan
    I absolutely hate those sink drain baskets with the big nut and nothing to easily grip to torque it down. Sometimes I wonder who designs this stuff and why.
  2. Aug 16, 2018 #22
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    743
    148
    North reading, Mass.
    I designed my own!
    anticlmatic likes this.
  3. Sep 19, 2018 #23
    Jamesplumbing06
    Jamesplumbing06
    Jamesplumbing06
    Feb 24, 2016
    556
    110
    I won’t ruin the punch line but I listening to hear the answer
  4. Sep 19, 2018 #24
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    743
    148
    I believe if you have to ask the question you likely wouldn't understand the answer.:p
  5. Sep 28, 2018 #25
    frodo
    frodo
    frodo
    Sep 28, 2014
    6,581
    2,075
    I finally found a metric crescent wrench, I had to drive around to 3 pawn shops to find it
    The pre-trained /experienced shovels I can help you out with
    the experienced Paulas do not hang out at the home depot
    they are a little more upscale and can be found a Lowes or Ace
    I carry a medium size can of whoopass on my truck for the really aggravating jobs and it can be found charged under Misc. materials on the invoice
    quantity 1 medium can whoopass @ $37.50
  6. Sep 28, 2018 #26
    Jamesplumbing06
    Jamesplumbing06
    Jamesplumbing06
    Feb 24, 2016
    556
    110
    Has anyone ever found one those special HOT water heaters? I need my hot water to be hot. Again.
    I sent my new guy to truck for that pipe stretcher. He brought me my expansion pex tool. guess that technology has caught up with the “get away from me for a minute” tool.
  7. Sep 28, 2018 #27
    frodo
    frodo
    frodo
    Sep 28, 2014
    6,581
    2,075
    here is a fitting you can send him after
    a 2 x 2 x 2 san tee with a 3'' side outlet
    i had a smart ass bring me back a box of tees and bushings, told me to wing it
    i kept that dude. lol
  8. Sep 28, 2018 #28
    Jamesplumbing06
    Jamesplumbing06
    Jamesplumbing06
    Feb 24, 2016
    556
    110
    Yeah at least they listening to the words. I gonna have to try that fitting with a few experienced guys.
  9. Sep 30, 2018 #29
    Jamesplumbing06
    Jamesplumbing06
    Jamesplumbing06
    Feb 24, 2016
    556
    110
    I have never understood maximum drop. Somebody please tell me how to get from top floor to bottom floor with drain. And not exceed the maximum? Whatever a maximum is. So many have tried to explain how water can outrun solids. But I run a plumb straight vertical pipe. Is that maximum? And newton says gravity acts equally on every object. The maximum really only apply to a vented arm over. That I know of. But if everything behind your slope is vented then let it fall.
  10. Sep 30, 2018 #30
    Mikey
    Mikey
    Mikey
    Jul 16, 2018
    123
    16
    Northwest Washington
    Newton and Galileo were right, and a recent experiment shows it dramatically; I loved watching those high-powered scientists gawking over it:
  11. Sep 30, 2018 #31
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    743
    148
    I believe that reference is primarily a civil criteria. It is referring to horizontal piping(less than 45 degrees) And apparently it is related to limiting the Maximum velocity due to the concerns you mentioned about the liquid leaving behind the solids. I've seen references to max velocities being limited to anywhere between 10 degrees all the way up to 15 or 20 degrees.
    EDIT: Oops not degrees, feet pet second velocities.
  12. Sep 30, 2018 #32
    FishScreener
    FishScreener
    FishScreener
    Aug 23, 2018
    172
    57
    83467
    A sewer line is not a vacuum, and when they flow through the pipe, unless you have made a slurry out of the waste, the fluids outrun solids.
    I was in Vegas, when the low flow toilets, and water conservation hit. (My younger brother still works for the Water Authority there.) in addition to the code mandated devices, they started installing all sorts of the water saving devices, dual flush, etc., that were hitting the market. The Water Authority would pay for projects, to decrease usage. The Hotels all incorporated the savings projects in to their regular cycle of remodeling. Most folks don’t know it, but the high dollar strip hotels, do complete remodels every year on the high end floors, and at least every three years for all guest areas. The big hotels have in-house crews of tradesmen, and do their own work, and it is a continuous process.
    Within three months of installation, they had to start snaking the lines on the remodeled floors, because they were having the fluids out run the solids in the “horizontal” runs. They hadn’t changed the slopes, because when you had high volume fixtures, the code worked. But, no one had thought through the effect of cutting the water volume by over thirty percent. There wasn’t enough volume to flush the. Solids to the vertical stack.
    We had physical models of sewer lines, made out of clear polycarbonate, set up at the university, and mixing up something called floop, to simulate solids. And, spent several months, flushing floop, down toilets, and watching it run down the clear lines, to determine how much slope you needed, to move the floop, consistently and get the solids to run all the way to the vertical stack. And the plumbing code for Clark County got modified.
    The maximum vertical drop in a stack, is driven by the energy involved in the drop, the impact energy at the bottom of the drop, and how strong the waste lines are. If a slug of waste falls too far, it develops enough energy to start loosening, and eventually breaking the joint at the bottom.
  13. Sep 30, 2018 #33
    Mikey
    Mikey
    Mikey
    Jul 16, 2018
    123
    16
    What slope did you come up with?
  14. Sep 30, 2018 #34
    Jamesplumbing06
    Jamesplumbing06
    Jamesplumbing06
    Feb 24, 2016
    556
    110
    Ok I can see the utility side of it. I guess. My theories are not as justifiable as a college classroom experiments. But codes do come from somebody sitting around thinking of ways to go wrong. I just assume everybody showers after taking a floop and the rest of the upcoming water will push the floop down.
    Always wondered if somebody spent the cash to test a bowling ball and feathers in a vacuum. Guess there is a dollar for everything lol.
  15. Sep 30, 2018 #35
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    743
    148
    The potential of lack of sufficient volumes of flushing water, in low flow toilets, was recognized during their design.
Share This Page
