I have a Pfiister 0X8 series valve (single handle) and am trying to remove the Adjustment Gear so I can set the water output a tick hotter. This must be done in order to rotate the stem counterclockwise, and then the Adjustment Gear is to be reinserted.
The gear is supposed to be grabbed by a tiny plastic tang located at at "6:00". However, when I grab that tang and pull with considerable force, the gear does not budge. It's quite stubborn and I do not want to tear off the tang !!
Has anyone else seen this frustrating problem?
