PEX Crimpers
Discussion in 'Plumbing Tools and Equipment' started by JennyTools, Jul 28, 2010.
  1. Jul 28, 2010 #1
    JennyTools
    JennyTools
    JennyTools
    Jul 28, 2010
    Hi Guys,
    I'm new to the site/forum but not to the plumbing industry. My father and uncle have owned and operated a small manufacturing company in Pipersville, Pennsylvania (since 1973) that has since become the family business. We primarily manufacturer hand tools for the electrical industry, but recently have started manufacturing PEX Crimping Tools for professional plumbers and other DIY types.
    Proudly manufactured in the USA, our Compact PEX Tool with Interchangeable Dies (patent pending) makes pex crimps even when placed literally against the wall. Utilizing our four link mechanism, this tool is the ideal solution for your crimping needs. Unlike other products, the unique interchangeable dies of this crimper allow the operator to quickly and easily change pex size with no additional tooling. As always, our many PEX tools are designed with overhead applications in mind. This line of tooling makes short work of any crimp that requires two hands to position the tool on the fitting.
    [​IMG]
    [​IMG]
    [​IMG]
    My main point is this, check out our site at http://jennytools.com/ today!
    Thanks,
    Steve
  2. Oct 14, 2010 #2
    clydewater
    clydewater
    clydewater
    Jan 30, 2010
    West Trenton, New Jersey
    HI
    What vendors rings will these tools work with?
    Thanks
    Rich
  3. Dec 16, 2010 #3
    plumbernyc
    plumbernyc
    plumbernyc
    Nov 30, 2010
    22
    NY, ny
    Good to see American manufactured tools.
  4. Dec 17, 2010 #4
    majakdragon
    majakdragon
    majakdragon
    Professional Professional
    Jan 7, 2010
    297
    Lafe Arkansas, Arkansas
    I still think this "one post" member is advertising.
  5. Dec 17, 2010 #5
    SlowDrip
    SlowDrip
    SlowDrip
    Plumbing Sales Professional
    Nov 15, 2010
    395
    Oshawa, Ontario
    ReeeeaaaAAAlllly?
    :D
    breid1903 likes this.
  6. May 15, 2011 #6
    Another-Plumber
    Another-Plumber
    Another-Plumber
    May 14, 2011
    233
    6
    San Diego, Ca
    i dont like the inter changeable dies, i would rather have 2-3 different tools than that trash, besides, when running pipe, you are most likely using only one size or the other, 1/2 or 3/4 so on, as your partner can be using the other tool, up above in the attic... so the small dies for me is a bad idea..
  7. Jul 25, 2011 #7
    johnjh2o
    johnjh2o
    johnjh2o
    Senior Member Professional
    Jul 21, 2011
    3,205
    733
    Melbourne, Florida
    What someone needs to make is a crimping tool with a ratchet, similar to a PVC cutter. Then you wouldn't need the long handles and they would work in tight spaces.
    John
    phishfood likes this.
  8. Jul 25, 2011 #8
    havasu
    havasu
    havasu
    Jan 6, 2010
    8,954
    1,168
    Southern California,
    Sounds like a great idea John!
  9. Jul 25, 2011 #9
    johnjh2o
    johnjh2o
    johnjh2o
    Jul 21, 2011
    3,205
    733
    Melbourne, Florida
    Lets build one and we can sit back and collect royalties like the plumber that came up with the Fluid Master. Oh buy the way I saving this post in case someone comes out with one.
    John
  10. Jul 25, 2011 #10
    Will
    Will
    Will
    Jul 23, 2011
    9
    Moore, Oklahoma
    I don't like the changing heads. I'd rather spend more and get one tool for each size, because it will last more in the long run. If my Mil 3 crimpers ever where out I might give yours a shot, but don't hold your breath. My Mil 3 crimpers will probably outlast me.
  11. Feb 19, 2012 #11
    Pipedawg
    Pipedawg
    Pipedawg
    Nov 1, 2011
    6
    Too late Watts makes one and so does Zurn. I guess you'll have to keep working.
    http://s3.pexsupply.com/images/products/zoom/0651059-4.jpg
  12. Feb 19, 2012 #12
    johnjh2o
    johnjh2o
    johnjh2o
    Jul 21, 2011
    3,205
    733
    Melbourne, Florida
    Are those crimpers or a cinch tool?
    John
  13. Feb 19, 2012 #13
    LiQuId
    LiQuId
    LiQuId
    Apr 13, 2011
    868
    15
    , Alberta
    those are the cinch type, they work on the rings with the wings. have a built in diagnostic to tell that the ring has been properly crimped... and are a total POS. due to the pain in the ass you will have if you have to crimp a ring in an awkward spot. though they are awesome for rings in normal conditions .
  14. Feb 29, 2012 #14
    Matt30
    Matt30
    Matt30
    Jan 17, 2012
    1,922
    753
    Halifax, Nova Scotia
    Classic solid ring or wirsbo for me thanks. Dont need that fancy pants over priced junk
  15. Mar 5, 2012 #15
    LiQuId
    LiQuId
    LiQuId
    Apr 13, 2011
    868
    15
    , Alberta
    Overpriced? my crimp tools were $350 for a set and my Cinch tool ( a nice one ) was under $100 and do all sizes.
    to each their own though .
  16. Apr 6, 2012 #16
    PipeInspection
    PipeInspection
    PipeInspection
    Mar 9, 2012
    11
    I bought one from Home depot that basically crimps a small clip on the outside of the ring.
    It'll accept a 3/4" or 1" ring. I'm sure I can us channel locks to do the same thing. Since I have the crimper I don't need the channel locks for now.
  17. Apr 6, 2012 #17
    johnjh2o
    johnjh2o
    johnjh2o
    Jul 21, 2011
    3,205
    733
    Melbourne, Florida
    You can't crimp PEX with channel locks. The crimp ring needs to be compressed equally on all sides to make a joint. Even if the crimping tool is out of adjustment you won't get a good joint. They make a go no go gauge to check that they are adjusted correctly.
    John
  18. Apr 11, 2012 #18
    PipeInspection
    PipeInspection
    PipeInspection
    Mar 9, 2012
    11
    John, I believe you can . I believe the Crimp too is made by Shark Bite. It's not a complete 360 degrees ring. The ring is about 270 degrees, than has two extruding pieces that complete the ring. One going in each direction.
    Basically, you put the Shark bite crimper on the outside of those two pieces and squeeze it together.
    I'm sure if you didn't have the crimper you could use Channel Locks. I'm not saying you should use Channel Locks to save money. It would be best to buy the right tools to complete the job, even if you're going to use it once in a while.
  19. Apr 11, 2012 #19
    johnjh2o
    johnjh2o
    johnjh2o
    Jul 21, 2011
    3,205
    733
    Melbourne, Florida
    It sure looks like a 360 degree ring to me.
    http://www.homedepot.com/buy/sharkbite-multi-head-crimp-tool-kit-314046.html
    John
  20. Apr 11, 2012 #20
    LiQuId
    LiQuId
    LiQuId
    Apr 13, 2011
    868
    15
    , Alberta
    I think what is being referred to is the pinch rings, which I would imagine if you HAD to you could pinch with channel locks ( why one would Is beyond me ). You could not possiblly get a proper connection using crimp rings with channel locks ( again why you would ??? the tool is only 60 buck now, when i bought my set they were 300 a pop )
Share This Page
