ymg200
Hi,
This is my first ever experience with PEX. I bought a manual expanding tool made by iCrimp (the model with auto-rotating head), 1/2" Apollo pipe and Apollo expansion rings.
I've tested how the tool works by expanding the pipe. I have verified that the barb (made by Apollo) can go into the expanded pipe, then removed the barb before the pipe has shrunk. I assumed that the pipe would return to it's original size, but it did not. I waited for couple of hours waiting for the pipe to shrink. Attached pictures show two ends of the same pipe - the original size and after the expansion. The expanded end shrunk enough so that I could remove the expansion ring, but it is still way bigger than non-expanded end. Before the expansion the barb could not go into the pipe at all. After the expansion I can easily insert the barb into the pipe up to the tall ridge that's in the middle of the barb. This indicates that if I left the barb inside the pipe, it would have sealed only on that single tall ridge. If that was by design, then there would be no need for other ridges on the barb.
As I said, I had no prior experience with PEX, so I have nothing to compare this to. Is it possible that the pipe doesn't return to it's size because the tool expanding it too much? Should the pipe shrink back to it's original size and become smaller than the barb like it was before the expansion?
