Nukedaddy
I know the difference in the formulation method for the two kind of PEX tubing. And that PEX-A is the one that uses the Wirsbo-UPONOR type of fittings with expansion rings instead of the compression rings, clamps or Sharkbite fittings used with PEX-B (Silane process) tubing.
My question is somewhat theoretical or speculative. If PEX-B is used with the expansion fittings instead of the intended compression types, will it necessarily be a leaker? The tube end is reinforced with the expansion ring. Both A and B tubing have material memory. PEX-A may have “more” memory than B, but is the difference really all that much?
I want to hear from the combined experience of our august members. I can go with the “because the manufacturer says to” or “why would you want to take a chance”. Both reasons are valid.
BUT: I want to know if anyone has specific knowledge of tubing failures due to using expansion fittings on PEX-B.
