My aerobic septic tank (Aqua Safe 500 gal. trash with 750 gal. pump tank) has three float switches. The lower one is controlled by a timer and turns on the pump/sprinklers at night. The middle one was an override switch which was always powered and would turn on the pump/sprinklers during the day if necessary (it rarely, if ever, was). The upper one was for a high-water alarm.
A few weeks ago, my lights started flickering, and I eventually traced it to the septic circuit and an underground junction box where moisture was causing arcing. The septic control box lugs were all rusted shut and my maintenance company wanted to replace the box along with the wiring, which they did this week.
When I checked it today, I found that they had not connected the override switch. Actually, they connected the middle float switch to the high water alarm, and left the top one disconnected. The new control box has a lug for override, they just didn't install the wire for it.
I plan to call them Monday I just wondered if anyone can explain why they wouldn't reconnect the override switch.
