Once in a while,
sawsaw
Nov 24, 2010
105
31
Cottage Grove, MN
I wonder how much water, if any, is acceptable to course from the bath tub spout when the diverter is engaged?
What say you?.
BlueSkyHigh
Supporting Member
Jun 17, 2021
702
466
Northern Virginia, USA
I don't like any so I was continually replacing the spout with the pull-up diverter. I then changed to a spring loaded pull-down type and it's been good for a year or so now with (nearly) zero drip.
sawsaw
Nov 24, 2010
105
31
Cottage Grove, MN
I, also have the pull-down, which has a healthy little stream. When I find a few spare minutes, I will remove the spout ... probably an O ring failure.
Twowaxhack
Professional
Professional
Feb 9, 2021
9,275
4,089
United states
If it’s a Delta there’s no repair on record. But I’ve often repaired things that are said to be not repairable.
Take a pic and let me see what you have.
BlueSkyHigh
Supporting Member
Jun 17, 2021
702
466
sawsaw
Nov 24, 2010
105
31
Cottage Grove, MN
Thanks for offer! However, went in the catycombs and found the receipt, dated 2000, and info sheet for the diverter. It is a Delta. So, I called Delta Faucet ... they are sending a free replacement! Their list price is $98!!
