Old pipes in renovated house
Discussion in 'General Plumbing Help' started by SBR, Mar 15, 2019.
  1. Mar 15, 2019 #1
    SBR
    SBR
    SBR
    Mar 15, 2019
    Alexandria, VA
    Just bought recently renovated house, only to have immediate water damage from 18-inch crack along ~65 year old cast iron pipe. Plumber cut out damaged section with reciprocating saw and installed PVC with clean-out port. Two questions:
    1) Has anyone seen further problems from vibration caused by reciprocating saws?
    2) Would anyone else have added support for old pipes, or do the connections between the CI and PVC provide adequate support to minimalize further stress on old pipes? Original metal support bands anchored to wooden joists are visible.
  2. Mar 15, 2019 #2
    Geofd
    Geofd
    Geofd
    Professional Professional
    Jan 20, 2018
    1,207
    168
    Boston, Massachusetts
    cutting ci with a Sawzall is usually not a problem...did you have him check the rest of the pipe....the coupling he would use would be a stainless steel shielded 2 band transition coupling one side excepts the ci the other side the pvc I think the brand is pro flex
  3. Mar 16, 2019 #3
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,193
    2,242
    you need a support on both sides of any band that is installed on a horizontal hanging cast iron pipe
Share This Page
