Old bathtub water-supply brass fitting
Discussion in 'Showers and Tubs' started by irhunter, Jan 19, 2020.
  1. Jan 20, 2020 #21
    irhunter
    irhunter
    irhunter
    Active Member
    Jan 19, 2020
    25
    6
    Maine
    I now realize that open-top 1.5" pipe used to be part of the bathtub drain-stopper control. There used to be a rod going down that pipe to control a drain stopper.
  2. Jan 20, 2020 #22
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    1,333
    220
    Chicago suburbs
    The teflon pipe dope you showed earlier will work with the teflon packing.
    No need for that big 16 ounce jar from Amazon.
    You will need just a few pea-sized blobs of it.
  3. Jan 20, 2020 #23
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    1,333
    220
    Chicago suburbs
    Yes, your middle handle used to raise and lower a plunger type stopper.
  4. Jan 20, 2020 #24
    irhunter
    irhunter
    irhunter
    Active Member
    Jan 19, 2020
    25
    6
    Maine
    Thanks. Yes, that dope was what I was planning on using.
    I live in a town of 1,500 with two so-called hardware stores both with so-called plumbing departments. When I went in today to buy the packing, in both cases, they gave me that "What you talin' 'bout Willis" line. They profess to have no knowledge of such an exotic product as teflon valve packing.
    I suspect, the truth is, they were not interested in ordering me a $4 item. This was at a time of zero other customers in either store. Geeze.
    So, my packing is coming via Ebay.
    I now also recall my GF taking the stopper apart...I suspect the parts are somewhere.
    Roy
  5. Jan 21, 2020 #25
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    1,333
    220
    Chicago suburbs
    I think at the very least that open vent will release stink, bath drains are always full of rotting hair and body oil.
    The old plunger drain plug assembly probably had a cap that was fairly airtight.
    Time to find that old stuff.
    Post some pics when you finish that bath wall remodel.
  6. Jan 22, 2020 #26
    irhunter
    irhunter
    irhunter
    Active Member
    Jan 19, 2020
    25
    6
    Maine
    It is not really a "wall." There is a shelf-kind-of-thing on top of what looks like the start of a wall. My house was just built by a "guy," probably without much in the way of "plans," and it has a number of odd components. Some of those are nice custom features; some are just odd.
  7. Jan 22, 2020 #27
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    1,333
    220
    Chicago suburbs
    I would add a full wall across the tub, to the ceiling, where the tub valves are now.
    Very strange trying to shower with that opening there.
    Drafty and goofy, and leaky.
  8. Jan 23, 2020 #28
    irhunter
    irhunter
    irhunter
    Active Member
    Jan 19, 2020
    25
    6
    Maine
    Well, the shower curtain wraps around. We bought this 1-bath house 15 years ago...at that time there were no signs that the tub had ever before been rigged for showers. For many decades this house was a bath tub only deal.
    I kind of like the open ends...it is a very small bathroom, and I think the openness makes it seem less like a bathroom in a 1970 camping trailer. More open, larger.
  9. Jan 26, 2020 #29
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    2,395
    414
    North Reading, Mass.
    I may be missing something here, but why wouldn't this require the typical large washer, which would be put on the pipe then compressed down with the follower nut?
    Granted, you would have to unscrew the vertical pipe to allow you to slip it on.
    EDIT: And select the correct size and type of washer.
  10. Jan 26, 2020 #30
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    1,333
    220
    Chicago suburbs
    Yes, a squishy rubber washer, or maybe a bevelled one, would work, but this old brass thing is probably at least 70 years old.
    Taking it apart to slide on a washer over the pipe is too risky, and unnecessary.
  11. Jan 26, 2020 #31
    irhunter
    irhunter
    irhunter
    Active Member
    Jan 19, 2020
    25
    6
    Maine
    Yes, a washer or o-ring would be nice.
    And, yes, too much disassembly to install. If I were to do that much disassembly, I would throw that fitting away and add a union...or, something along those lines.
    The teflon packing came in the mail, and I installed it. Still leaks a bit. I will tighten it down some more, and report back.
  12. Feb 1, 2020 #32
    irhunter
    irhunter
    irhunter
    Active Member
    Jan 19, 2020
    25
    6
    Maine
    I has been a week of no leaks. I used the full 24"-pack of packing...minus about 6". It took quite a bit of torque on the wrench to get it to stop leaking. I will keep the wall torn apart a good long time (months?), so to keep an eye on the fitting. I do not want to notice it has started leaking again by way of a ceiling leak.
    Trust but verify.
    Thanks to everyone who helped. I will report back if something goes bad.
    Roy
Draft saved Draft deleted
Share This Page
Group Builder
