Hi all,
This is a shot in the dark but thought this community may have ideas. I need to source a substitute for a badly-corroded flange from a commercial espresso machine boiler. The machine is 40 years old and I've reached out to manufacturers, hobbyist forums, parts suppliers--all with no luck.
The piece is cast aluminum with an inner diameter of 7 7/8" and outer diameter or 10" (unit has room for a larger OD). I can drill bolt holes. Does anyone have suggestions for a similarly-size flange from plumbing applications (steel or aluminum)? A company quoted $550 for an aluminum ring, custom machined (flat, no holes), which unfortunately is too expensive for this unit.
I'd be grateful for any suggestions. Many thanks all.
