Novice_home-owner
The o ring for my whole house water filter is wound (and tightened) into the threads connecting the filter cartridge’s casing to the base/top of the filter. I’ve noticed this after unsuccessfully attempting to get it off 1) using the plastic wrench, 2) using a second plastic wrench, 3) using pvc over the handle of one wrench as a lever (didn’t have wide enough pvc for two wrenches), and breaking the handle of that wrench, 4) hair dryer for several minutes, then hammer and mallet taps, then attempting with one plastic wrench, and finally 5) with a strap wrench (designed for oil filter) and ratchet, which didn’t work nearly as well (to get a baseline reference point for the tool) on my larger filter as the plastic wrench did - the larger filter can be loosened just fine. At this point do I just need to get someone to cut the copper pipes and install a whole new water filter, or is there any hope of getting this off with the o ring between the casing and base? It’s not worked its way up into the threads, as can be seen in the picture, but it’s clearly at the base of the threads under the casing, not seated where it should be.
