Immortanjoe
I recently had a plumber come by and replace the internals of the tank on my toilet. it's constantly running now, so I went in and noticed the water right at the top of the drain tube. I couldnt tell if it was overflowing, so I adjusted the float to it's lowest setting. It still continued to run. So I did a diy adjustment to the overflow, just to see if I could stop it running, but I noticed the pipe running into the drain tube (I'm sorry, I don't know the technical term for it.) was constantly on, which might be the cause of the problem. I attempted to lift the float to see if it stopped the flow, but it didn't stop.
I'm not the best at explanations, but I wouldn't mind some feedback. Is this a simple problem, or do I have to call my plumber back?
