New Vanityy & P-Trap question
Discussion in 'Toilets and Sinks' started by bucfanjeff, Feb 28, 2018.
  1. Feb 28, 2018 #1
    bucfanjeff
    bucfanjeff
    bucfanjeff
    Feb 28, 2018
    I have a 30" vanity that is being replaced with a 48" vanity.
    My question is, can the "out" of the p-trap be at a slight angle, left or right, going into the drain in the wall?
    The pic attached is the current sink.
    The new sink drain will come down vertically about 9" +/- to the left of the current sink shown here. As such, the p-trap-to-walldrain part will not be straight into the wall - or completely straight. So I'll have to come straight out of the wall drain, then a 45 degree elbow to go to the p-trap. In other words, using the pic as the example, instead of straight out of the wall drain to the p-trap, it would be straight out a little - then 45 degree a little - then straight into the p-trap.
    Is this ok and per code? I'm in SC.
    Thanks
  2. Feb 28, 2018 #2
    TomFOhio
    TomFOhio
    TomFOhio
    Professional Professional
    Jan 20, 2018
    583
    124
    Mansfield,, Ohio
    Yes, it is ok to do it that way. That's how I would do it also.
    bucfanjeff and Zanne like this.
  3. Mar 1, 2018 #3
    havasu
    havasu
    havasu
    Jan 6, 2010
    9,101
    1,233
    Southern California,
    Looking at the picture, it appears your p trap is not sitting exactly parallel with the chrome downspout. You may develop a slight leak unless you do a slight adjustment.
  4. Mar 17, 2018 #4
    justin_dewan90
    justin_dewan90
    justin_dewan90
    Nov 23, 2017
    269
    28
    Could you cut the extension tube down a little and then turn the ptrap for a straighter fit? like a previous person said you have potential for leaks. Should be able to shorten the extension tube some to make everything fit better.
    I do have another option to make this straight if the first option doesn't work.
Share This Page
