Hello,
I just purchased a 10 yr old home with an aerobic septic system. While checking out the septic, I found that the control panel (Aqua Aire 202) alarm was disconnected. there is a small 1/8" ID clear tubing that runs from the aerator pump (Medo LA-80BN) to the control panel to a broken switch in the panel for the alarm I presume. This small tube was pulling a slight vacuum a few days ago when I checked it, then yesterday, the same tube was blowing pressure? Is that normal? Thanks!
