RickVS
Hi. I have a 2 year old American Standard toilet that periodically 'runs', hikes my water bill, and fails the dye test.
When I look under the hood there is a cylindrical float and a cylindrical flapper that seems well-sealed to the bottom of the tank. There is also what I suspect is a smaller diameter overflow tube that has an even smaller diameter rubber hose that drains into it.
When I hear the toilet run, and I lift up the tank cover, I see water coming out of the rubber hose and into what I think is the overflow tube. So I am confused about how to repair this leak.
The flapper is solidly received by the tank bottom, so I don't think water is leaking there. Which begs the question of why would the toilet throw perfectly good water down an overflow tube?
Any help you can provide would be greatly appreciated.
Thanks!
Rick
Thanks!
Rick
