Need to Resolve Sewer Cleaning Issues
Discussion in 'Drain and Sewer Cleaning' started by AlbertGeorge, Mar 1, 2017.
  1. Mar 1, 2017 #1
    AlbertGeorge
    AlbertGeorge
    AlbertGeorge
    Mar 1, 2017
    Hey, I am AlbertGeorge.
    There is clog problem in main sewer line. plz suggest me any solution for this problem. :confused::confused:
  2. Mar 8, 2017 #2
    SHEPLMBR
    SHEPLMBR
    SHEPLMBR
    not a Junior Member anymore! Sponsor
    Mar 9, 2016
    621
    107
    NOKESVILLE, VA
    Have it inspected via camera for any breaks or intrusions. Then have it repaired or snaked.
  3. May 29, 2017 #3
    SepticTankdayton
    SepticTankdayton
    SepticTankdayton
    Septic Tank Dayton
    Mar 15, 2017
    Dayton, Ohio
    I would suggest calling a reputable sewer cleaning and/or septic tank company. I would talk to these guys first for any advice that you could do before calling them out and paying them. Then if they had to come out, I would have them assess what could be done and have them clean out and/or replace the pipes to the main sewer line. They could possibly use hydro cleaning equipment if it is really bad. I would also think about removing the trees in and around the main sewer lines to to avoid sewer snakes (roots that grow in the shape of pipes).
    Mr_David likes this.
  4. May 29, 2017 #4
    Mr_David
    Mr_David
    Mr_David
    Easily Amused Professional
    Jan 12, 2010
    3,868
    930
    Santee,Ca,
    Septic has some good advice
    Don't get all wound up on worrying about cutting trees down YET.
    Call around and ask question. Find a reputable company that knows what they are doing. There are a lot of drain cleaners that only know how to run a snake down the drain. Then they bull$h!t you into all kinds of unneeded repairs.
    If this is your first sewer stoppage it maybe just a wad of paper left by the use of the newer low flow toilets.
    Or the girls flushing their discarded mice instead of putting them in the trash.
    Get it snaked out and maybe that's all you need.
  5. Dec 16, 2017 #5
    plumbinggroup
    plumbinggroup
    plumbinggroup
    Aug 24, 2017
    7
    A Sewer Clean-Out is a pipe stub, located no further than three feet from the house on the Main Sewer Line, leading to the general sewer. Its main purpose it to help to Remove the Blockage in your Sewer.
  6. Jan 6, 2018 #6
    plumbinggroup
    plumbinggroup
    plumbinggroup
    Aug 24, 2017
    7
    Sewer Lines simply make difference in your day-to-day relaxed life. One of the fact that no one really understands is "when sewer lines become problematic, the problem remains invisible and you can only notice that something is wrong and you're soon going to face a plumbing blast" Says - TPG
  7. Jan 20, 2018 #7
    Geofd
    Geofd
    Geofd
    Professional Professional
    Jan 20, 2018
    362
    50
    Boston, Massachusetts
    I'm a plumber and I snake all kinds of drains the best way
    to find out whats going on with your drain is camera it then you can
    see dips breaks roots remember the line must be clean
    the camera won't see thru dirty water even if your drain is in
    rough shape there are companies out there that re line
    drains they can fix breaks all without digging anything
Share This Page
