Hello - I need help identifying the brand of this kitchen faucet. There are no markings or branding of any kind anywhere on the unit. I suspect there are some on the underside at the water connections, which I may have to get to if I cant replace the sprayer head. The head is blocked - tried a day soaking in vinegar, minimal luck as it flows for a second and then stops. Maybe a cartridge in there as well. This head has female threading, and I can't find a way to disassemble any part of it. Everything online seems to be male threading at the head. Two function only with a magnetic base in the back to attach to the arm. Grey plastic/rubber hose inside the spring assembly. Thanks for any help
UPDATE: I got under the unit and see a Kohler tag on the plastic connector hose feeding it. Not sure if it is a Kohler or just a hose they used. I looked all over Kohler's site and don't see one like this, and their replacement heads seemed to all be male threaded as well.
