fixitdude74
Hi all,
I have a pipe which i'm trying to identify the size so as to get a fitting to suit it.
Polypropolyene
32.4mm OD
24.75mm ID
3.8mm wall thickness
It appears to be PN16, but the wall thickness is thinner, none of the metric philmac 32mm spigots fit the ID, i'm scratching my head on this one.
The fitting that was on the pipe is a brass compression fitting with an split olive, and a plastic spigot.
Polypropolyene
32.4mm OD
24.75mm ID
